When try to run the exe built in LabVIEW 8.6 getting error with broken arrow..
The installer which built in LabVIEW 8.6 is getting installed successfully in all PC's. But in some PC's, when I try to run the application It says "The VI is not executable. The full development version of the LabVIEW is required to fix the errors". I am unable to run the Executable. Is there any problem?
(2,907 Views)
 Configuration of that PC having problem are  Windows XP, Professional Version 2002 with SP3
(2,899 Views)
You are missing a lot of information.
Please specify what kind of system are you building the exe file on, and what kind of system are you trying to install it on ?
Witch systems are working, and witch are not. What are the difference between these systems ?
(2,884 Views)
Thanks for thr reply and here are the details..
System Configuration of the PC which installer built using LV8.6.1 - Windows XP, Professional Version 2002 with SP3. The installer include LV runtime engine 8.6.1 and NI VISA server 4.5
System Configuration of the PC which having problem when running the application - Windows XP, Professional Version 2002 with SP3, labview not installed
Also with the above same pc configuration the application working fine.
(2,864 Views)
Are you using som DAQmx or other modules ?
(2,855 Views)
Im not using DAQ devices and any other modules, but i am calling some user DLL from specific location
(2,851 Views)
