When using Append Report Text.vi, the inserted text does not retain the original formatting (font name , size) applied to the bookmark
**Steps to Reproduce:**
1. In a Word template, create a bookmark with a placeholder string (e.g., "XXXX").
2. Select the entire placeholder text, apply custom formatting (e.g., font = Arial, size = 14pt, bold).
3. In LabVIEW, use `Append Report Text.vi` to insert content into that bookmark.
**Expected Behavior:**
Inserted text should inherit the formatting of the original bookmark placeholder (i.e., retain font size, style, font name).
**Actual Behavior:**
Inserted text reverts to default or Normal style. The original formatting is lost.
**Confirmed Conditions:**
- The bookmark is a proper *range* bookmark (not just an insertion point).
- Formatting is correctly applied in the Word template and visible before insertion.
- Behavior occurs both in LabVIEW IDE and compiled EXE.
- Same behavior observed across multiple PCs and with different templates.
(885 Views)
What do you mean "create a bookmark with a placeholder string"?  Just use the standard Insert->Bookmark.  Format is retained.
aputman
(861 Views)
