When using "Print Report" my default printer changes.
I have the need to print two different kinds of reports to two different printers depending on which report it is.  I use the Office toolkit and wire the correct printer for the report using the "Print Report" tool.  However, each time I do this, it changes the default printer in Windows to the printer wired.  I don't want to change the default printer just send the report to the specified printer.  Is there a work around?
Quentin "Q" Alldredge
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
(2,659 Views)
Hi The Q,
a workaround could be to read first which the default printer is, then print your page with the printer you want and then reset the stored printer to default. The information which printer is the default printer can be read from the registry.
Hope this helps.
Mike
(2,651 Views)
