When will LabVIEW 8.0 be compatible with Windows Vista OS?
I have applications that were developed to be compatible with Windows XP.  Will the applications be compatible with Windows Vista.  If I knew which parts of LabVIEW 8.0 were compatible and incompatible with Vista, it would be a big help.  If 8.0 is not compatible with Vista at all, then I need to know which version of LabVIEW will be compatible and its release date.
(3,475 Views)
See http://zone.ni.com/devzone/cda/tut/p/id/5539.
And, NI has not given a release date on the drivers.
(3,458 Views)
