When you change a value you have to press Enter to make this change
I would probably use a feedback node here instead of a shift register. But even having to press enter does not prevent anyone from entering a bad value, so you definitely need an entry control as suggested and maybe additional sanity checks in code before the new value is handed over to the rest of the code.
If there are only a few possible power values, maybe you could use a ring containing all allowed values.
(I am curious about you case structure in the upper right. What's in the TRUE case?
Message 11 of 14
(801 Views)
Well there is true constant. When reflected power is bigger than allowed it will stop program. Because when is activated boolean for RP limitation, it limits generator power.
Message 12 of 14
(784 Views)
So you created a Rube Goldberg.
If True, output True.  If False, output False.
Eliminate the case structure and just use the wire!
Message 13 of 14
(777 Views)
Hmm, that’s looking very stupid from me. I didn’t realise that. I am learning by myself. So my best friends are Google and YouTube. 😄
So I really appreciate it.
Message 14 of 14
(772 Views)
