Where I can I find Serial VISA Open function?
I'm currently running LV6i. I having trouble trying to locate VISA Open for serial communication. I looked under Functions>>Instrument I/O>>Serial and all I see is VISA Write, Read, and Close. Where is VISA Open? I'm new to LabVIEW so I'm still trying to find my way around.
Thanks.
Message 1 of 10
(4,147 Views)
Try Functions > Instrument I/O > VISA >Advanced > VISA Open
Oliver Friedrich
"Trung" schrieb im Newsbeitrag
news:5065000000080000007F340000-1005954886000@exchange.ni.com...
> around.
> Thanks.
Message 2 of 10
(4,147 Views)
There should be a VI called VISA Configure Serial Port in that palette. If its not then maybe someone was messing with your palettes or something. Try making sure that you have the default palette selected.
Good luck
Brian
Message 3 of 10
(4,147 Views)
When using VISA Configure Serial Port VI does it open the serial port for you too?
Message 6 of 10
(4,147 Views)
I think VISA automatically opens the port when it is specified in the VISA resource name.
Brian
Message 8 of 10
(4,147 Views)
I think the VISA open function is not required anymore because the VISA session is automatically opened when the VISA resource name is used in a VISA node.
LabVIEW, C'est LabVIEW
Message 4 of 10
(4,147 Views)
Thanks. I will look into VISA Session.
Message 5 of 10
(4,147 Views)
True, but they should have a function in the serial palette to configure the serial port.
Brian
Message 7 of 10
(4,147 Views)
Okay you have 4* but you should't post these huge bitmap files... 🙂 Even MSPaint can save as jpg...
Message 9 of 10
(4,147 Views)
Sorry, my bad, slight lapse of sanity... 🙂 It'll never happen again.
Message 10 of 10
(4,147 Views)
