Where are some subVI ?
Like DataSocketUpdate,I found DataSocketOpen SubVI colour of some example is different from Function Palette of LV7?Why?
(2,964 Views)
Some example VIs (like DS ReceiveImage.vi) use sub VIs (like DSOpenBuffered.vi) that were created for the examples. In general, to find the path of any VI or sub-VI, open the VI (if it's a sub-VI you can open it by double-clicking on its icon on the calling VI's diagram), and from the VI's menu, goto File >> VI Properties >> General: the path is shown as Location. If double-clicking on the icon doesn't open a front panel, the item may be a function, not a VI.
The DataSocket function panel includes the DataSocket Open function with a yellow icon. DS ReceiveImage.vi includes a sub VI DSOpenBuffered.vi with a white icon. DSOpenBuffered.vi is a VI that builds on the DataSocket Open function. If you open the diagram for DSOpenBuffered.vi, you'll see that it calls the
DataSocket Open function then uses a property node to setup a datasocket buffer.
Often, icons from NI are yellow for functions, white for VIs. It's just a visual clue to tell you what the item is.
(2,964 Views)
ths.If I need some sub VIs that exist in some example,but I don't know there it is.What should I do?I want to know where I can see all available sub VIs?
(2,964 Views)
The examples are in multiple directories with many VIs in LLB files. I think the best way to browse them is to goto Help >> Find Examples from any LabView window. If you have opened a VI that uses a subVI you need, you can find the location of that subVI by going to File >> VI Properties as I explained in my earlier answer, or you can do a cut and paste from the diagram of the example to your diagram.
In LabView 7, you can also enable browsing LLB files using Windows Explorer: goto Tools >> Options to see that option. But I like searching or browsing using Find Examples: you can see the description of most example VIs as you browse them.
(2,964 Views)
