Where are the bluetooth errors described?
I can't find a listing that describes the meaning of the various Bluetooth errors I get when trying to connect my PDA-base app to a test server on my PC
Some of the error codes are 12615 and 12579
There are no errors in this range in the error code list in LabVIEW
Anyone have any idea where to look?
Senior Software Development Engineer
Certified LabVIEW Architect and LabVIEW Champion
https://theLonelyAnt.com
https://GDevConANZ.org.au
(2,894 Views)
You are correct that the error codes in this range are not documented/specified in LabVIEW.
Can you give us more information on when and where (in which Bluetooth VIs) you get these errors?
Thanks and best regards,
Shakhina P.
(2,866 Views)
