Where can I download cRIO Firmware
Hey, going through setting up my cRIO and looking at updating the firmware.  There is a cfg file available to use in order to update, but how do I know it's the latest and greatest?  Where can I check for that?  I have been all through NI and have found nothing useful in that area.  When updating my NI software via NI Update Service, does that automatically give you the last .cfg files for all cRIOs?
(6,891 Views)
The firmware should come as part of the CompactRIO driver if I remember correctly.
(6,850 Views)
Found on my system here:
C:\Program Files (x86)\National Instruments\Shared\Firmware\cRIO\####
Greg Hahn
Sr. Hardware In the Loop Firmware Engineer - CLD
Milwaukee Tool - https://www.milwaukeetool.com/
(5,401 Views)
That works if you have found it, or an installer has already put it in that location.  You just answered where the firmware is located AFTER it is already downloaded.
But I believe the original quesion is related to where updated firmware is located on NI.com to be downloaded.
(5,392 Views)
You might try filing a Support Request -- I needed up update the firmware on a myRIO (don't ask how I messed it up!), and the Technical Engineer at NI was able to provide me with it.
Bob Schor
(5,365 Views)
