Where can I download niDMM Control.vi?
Hi all,
I'm relatively new to Labview programming and I just need a little assistance with a couple basic questions.
I recently finished developing an electrical test harness for a PCB using Labview. I developed it on a computer in our production area and now that computer is being used heavily. I need to make some changes to the software but I will need to work from my desk and then push the updates out to that computer. Unfortunately, the production computer has some .vi's, etc. that my desk computer does not have. I've tried doing a search on the Prod. computer for the required files but I'm just having a hard time finding them.
This is a stupid situation to be in and I thought maybe I could get some help from this forum to resolve this issue efficiently.
I need to find "niDMM Control.vi".
Where should I look for it on the Production computer?
-or-
Where can I download it?
Thank you for your help, in advance.
(2,915 Views)
The actual location of the niDMM Control.vi is the following:
<LabVIEW Install Folder>\instr.lib\niDMM\nidmm.llb\niDMM Control.vi
HOWEVER, if you just copy over these files you will likely be missing other things and have other linking issues.  The right thing to do is open MAX on the other machine then open the software section on the left and look for the version of NI DMM that is installed.  Then you should install that version on your computer which will add all the files to your instr.lib that is needed.
(2,912 Views)
Install the niDMM drivers on your desk computer.
GCentral
(2,911 Views)
