Where can I find DDE execute vi
Hi all,
I need to communicate with an third party software (OPUS). The communication available is DDE Based.
With the example, there's a connect vi, close connection, request and poke vi but no execute one.
Where can I find that?
Thanx
Dai
Dai
LV 7.1 - WIN XP - RT - FP
Message 1 of 11
(4,948 Views)
It's in the same place you found the others - \LabVIEW\vi.lib\platform\dde.llb. Don't try to find any DDE functions on the palette. Even though they still ship, NI removed all DDE functions from the palette a long time ago due to Microsoft dropping support for DDE and so few applications supported it.
Message 2 of 11
(4,936 Views)
Oups,
Thank you very much, I did not look in this library. I searched for dde files and did
not looked at this one I suppose.
Unfortunately, OPUS only support DDE. It is possible to access OPUS through
OPUS Process via OPC but the communication is very limited. You cannot
access all the functions...
Dai
Message 3 of 11
(4,929 Views)
For anyone still looking to control OPUS with labview, note that an ActiveX interface is available free of charge (via e-mail) if you talk to one of their support folks.
Message 4 of 11
(4,792 Views)
Could you please send me this ActiveX interface?
Thank you
Message 5 of 11
(4,619 Views)
Hi eruvi,
I believe the ActiveX interface would be available from Opus software itself, www.opussoftware.com.
LabVIEW's ActiveX VIs can be found in the Connectivity palette.
Jeremy_B
Message 6 of 11
(4,575 Views)
Hi geremy_B
May you have any example code of controlling OPUS via Labview? it's really can help me
Thank you
Tomer
Message 7 of 11
(4,559 Views)
Hi Tomer,
We do not have any example code unfortunately (that I am aware of).
Here's a link to an intro on using ActiveX with LabVIEW, hopefully it might help you out: http://zone.ni.com/devzone/cda/tut/p/id/2983
Jeremy_B
Message 8 of 11
(4,545 Views)
Once you are comfortable with Labview and ActiveX (and have downloaded the OpusCMD package), the code should be pretty striaght forward
 TakeBackground a = new OpusCMD334.TakeBackground();
 QuickSample q = new QuickSample();
 bool error = a.TakeReference(XPMFile); //XPMFile is the filename for a scan method you've created
 bool error = q.QuickSample(XPMFile);
Your data is now in q.DataArray, which is a 2D array of double.
That's in C#, but it should point you in the right direction for what to call in Labview.
Don't forget to read the documentation that comes with the package. It's a bit wordy, but all the info you need is there.
-Jay
Message Edited by JayK. on 08-06-2008 11:32 AM
Message 9 of 11
(4,543 Views)
Thank you very much
Message 10 of 11
(4,531 Views)
