Where can I find "NI-845x Close Reference.vi"
I've downloaded drivers for the NI-845x and IT-E132 and cannot find several VIs, such as "NI-845x Close Reference.vi", "NI-845x I2C Write.vi", and "NI-845x I2C Close Configuration Reference.vi". These VIs are discussed in the user guide so I know they exist. Any help is appreciated.
Thank you.
(4,388 Views)
Accepted by topic author chuck72352
They're right on the main functions palette.
Never heard of "NI-845x I2C Close Configuration Reference.vi". Don't see it in the Help either.
(4,380 Views)
Thank you! I also found "NI-845x Close Reference.vi, it's in ni845x.llb
(4,377 Views)
You were asking about "NI-845x I2C Close Configuration Reference.vi". That's not the same as  "NI-845x Close Reference.vi". Did you install the NI-845x drivers properly?
Also, why did you upload the library?
(4,347 Views)
I loaded the driver a second time and that seemed to resolve the issue. I uploaded the library where I found the VIs that I was looking for, both NI-845x Close Reference.vi and NI-845x I2C Close Configuration Reference.vi, both of which I was looking for amoung others.
Thank you.
(4,345 Views)
