Where can I find the Labview file OPENCFG1.VI
Does anyone know where I can find the LabVIEW file OPENCFG1.VI?  It would be nice to have a simple text file which list the entire LabVIEW llb directory structure with vi's or a working search function built in.  Maybe I'm not aware of one.  I seen some that browse individual llb's, but not one that does the all llb's.  SS
Message 1 of 14
(3,332 Views)
At least in 7.0, there is Tools>>Find VIs on Disk. It didn't find such a VI on my computer, though. Are you sure it's NI's?
___________________
Try to take over the world!
Message 2 of 14
(3,290 Views)
I was also unable to locate this VI in LabVIEW 8.5.  It must have been a VI that you created or edited.  Please let me know if you need anymore help, thanks
Message 3 of 14
(3,272 Views)
I think you are correct it is a custom vi.  I'm requesting it from it's original source from France.  The fact that it was one of three vi's with an english file name made me think it was a Labview original, since the other two vi's with english names were from NI.  I do like the search built into LabVIEW and it works like a charm diggin into llbs.  Thanks for your help.  SS
Message 4 of 14
(3,269 Views)
No Problem! Good luck finding it 🙂
Message 5 of 14
(3,265 Views)
I found the problem.  When I tried to convert an llb to vi's in a file labview did not allow OPENCFG1.VI to be converted.  I believe this was created in 7.0 which I do not have.  Could I get someone from NI to please convert the VI for me? Regards, SS
Message 6 of 14
(3,240 Views)
Hi ShotSimon,
its not easy to help you, because this vi has no block diagram.
Mike
Message 7 of 14
(3,235 Views)
I'm being told by an advanced user of Labview in France that this is a standard vi. from possibly a version prior to LV 7.0.  Does anyone know how to locate such a file and translate to 8.5? SS
Message 8 of 14
(3,215 Views)
I can't even open it in 7.0. It returns a resource not found error and says it could not load the front panel.
___________________
Message 9 of 14
(3,208 Views)
There is absolutely no way to convert a VI without a diagram to a different version. When the VI is recompiled to a new version, the source code is required. The diagram is the source code so you're goting to have to recreate it or find the original VI with diagram.  Please let me know if you need anymore questions.
Message 10 of 14
(3,193 Views)
