Where can I find the driver required for my PCI-1200 data acquisition board?
(5,802 Views)
Duplicate post.
The PCI-1200 is a DAQ board, so you would use DAQmx to program it from LabVIEW. Do you have DAQmx installed?
(5,794 Views)
Correction: The PCI-1200 is a legacy DAQ board, so you would need NI-DAQ, v6.9.3, which you can get here.
Message Edited by smercurio_fc on 06-26-2007 05:11 PM
(5,793 Views)
Hi There,
Goodays. Did you have the legacy driver for 6.5.1 on PCI1200?
(4,856 Views)
You can find 6.5.2 here.  http://joule.ni.com/nidu/cds/view/p/id/190/lang/en
(4,852 Views)
The link that Ravens Fan posted should work for you, but I am curious why you are specifically looking for the Traditional NI-DAQ 6.5.1 driver. The NI-DAQ drivers were developed up to version 7.4.4 before being replaced by the DAQmx drivers in newer versions.
If your setup does not specifically require the 6.5.1 driver, I would recommend looking into the DAQmx drivers as they are easier to program with, faster, and more reliable.
Matt
NI Community Team
(4,845 Views)
