Where can I find the old 2D and 3D Industrial Controls that were sold as an option in early LabVIEW. The ones with pipes and pumps, etc.
A long time ago, I purchased as add-on to LV that had some rendered 2D and 3D pipes and pumps setup as custom boolean controls.  I can not find my old ones.  Are they still available somewhere?
(3,662 Views)
These were part of the DSC toolkit.  They were called something else back before the dsc toolkit.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,650 Views)
Do you know if it is available anymore?
(3,636 Views)
Accepted by topic author wa5ycg
I believe the images were originally provided by software toolbox (http://www.softwaretoolbox.com/)
You can still by the static symbol libraries or the active controls, however they are all activeX controls if you purchase directly from them.
Greg Sussman
Sr Business Manager A/D/G BU
(3,625 Views)
Just to add to Paul's answer, the LabVIEW Datalogging and Supervisory Control (LV DSC) still distributing the libraries. After installing, you can go to 'Tools' menu and under the DSC Module, you can find the "Image Navigator" which launch the UI to choose the pictures.
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,612 Views)
I downloaded LV DSC 8.6.  then started LV2010 and looked in Tools pull down, but there was no DSC module there.  Do I do something wrong?
S
(3,505 Views)
Hi... Evry ToolKit or module must mach the same vrsion of LabVIEW,thats mean if u have LabVIEW 2010 u must istall DSC 2010
(3,501 Views)
