Where can i find flat sequence in a function palette
Hello
Where shall i find flat sequence in the function palette of LabVIEW 6.1 version.
Please have a look at the VI in LabVIEW which i developed using LabVIEW 7.0 version, in which i used flat sequence.
Jayaprakash
(2,389 Views)
Hi
The flat sequence is just available in LV version 7.0 and newer.
In LV 6.1 you have to use the stacked sequence-structure.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,385 Views)
