Where can i find the User32.dll header files?
Hi
Is there any way to get the header file and library file of User32.dll or If I want to use a function from a User32.dll where can i get the parameters and arguments for that function which is required to call.
Thanks & Regards
Samuel J
System Engineer
Captronic Systems
samuel@captronicsystems.com
(16,477 Views)
Hi Samuel,
see MSDN for the info you need, e.g. this:
http://msdn.microsoft.com/en-us/library/ms646260(VS.85).aspx
Mike
(16,476 Views)
Accepted by topic author Samuel_James
In general you don't need "user32.h" because the functions are declared in Winuser.h (you should include Windows.h).
Otherwise, if you need user32.h only, then you can get this file together with Debugging Tools
After install you will get this file at C:\Program Files\Debugging Tools for Windows\winext\manifest\user32.h
regards,
Andrey.
(16,463 Views)
