Where can i set the debug-options?
i have a custom Labview-OPUI that calls teststand.
When exiting i get this error-popup. It immidiately freezes and i can scroll completely down.
Can someone tell me where i can change these debug-warnings?
Thx
(2,390 Views)
Open the sequence eidtor.  Select Configure -> Station Options.  Then select the Preferences Tab and click on the Debug Options button.. ( near the bottom of the screen ).  This will bring up a new window with options you can select or deselect.
Although, I would be more concerned why you have that many property objects not being released?
PH
(2,366 Views)
So this message is coming from teststand and has nothing to do with labview?
What for example is a not released Top-Level-Property-Object?
For what do i have to search to minimize them?
Thx
(2,353 Views)
You will get some further informations here:
PropertyObjects Were Not Released Warning When Using LabVIEW
http://digital.ni.com/public.nsf/allkb/C340060ECAFAA169862573C900723541?OpenDocument
Johannes Graeper
Applications Engineering
(2,336 Views)
