Where do I find the Labview uninstaller?
I can find support notes on the NI website referring to uninst.exe, but I can't find the file anywhere. Is this still a supported tool and is it supplied with the default Labview DVD set? I am having a problem installing the latest Labview drivers disk due to a conflict with an old version of CVI on my work PC and would like to clean everything up and do a fresh install.
(2,550 Views)
Control Panel -> Add/Remove Programs (Programs & Features for Windows 7). Then find "National Instruments". Then click "Change/Remove" (or "Uninstall/Change" for Windows 7).
(2,543 Views)
I'd looked there, but the Program Size reported for National Instruments was way too small to be the full package.
(2,541 Views)
Ignore it. It's wrong. Just launch it. Did you try?
(2,538 Views)
No, I guess I didn't want to make things worse with a partial uninstall. If the small reported size is normal I'll give it a go tomorrow.
Thanks for the help.
(2,533 Views)
