Where is the DAQ Assistant?
I am learning how to use LabVIEW 7.1.1 student edition with the "Introduction to LabVIEW" interactive training CD.  I am building a vi that requires me to "Place the DAQ Assistant Express VI located on the Functions»Input palette" but it is not there any more.  I had used it previously and now it is gone.  I re-installed LabVIEW hoping it would bring the DAQ Assistant back but it is still not there.  When I re-installed, I was promted to insert the "Drivers" cd, but this was not included in my software package.  How do I get the DAQ Assistant back?
Thank you...
(3,912 Views)
Hi scheme-
If you do not have the Driver CD available you can download the NI-DAQmx driver here.  This should install DAQ Assistant support for LabVIEW.  Please post again if you have additional problems.
Hopefully this helps-
Tom W
(3,908 Views)
Thanks Tom!
The download and installation went perfectly.  Now I can finish my homework!
-James
(3,901 Views)
Thank you for your help. I have the same  problem. Now you had solved it. thank you.
Richard
(3,325 Views)
