sagashe,
The results module is no longer available, but the results are accessible individually. Are you wanting to just edit the error messages? You can clear the status of the inspection, but that would defeat the purpose of inspection. If you could explain a little more what you are trying to do I would be able to help more easily, thanks!
-Allison S.
Calibration Services
Product Support Engineer
