Where is the Waveform Indicator?
Anyone used "LabVIEW for Everyone"? in one exercise there is a Waveform Indicator, it shows t0 dt and Y. Where do I find it or is it an array?
(3,998 Views)
Look on the I/O palette.
(3,998 Views)
Kivas;
It is on the Control palette, in the Graph menu. It's the "Waveform Chart". If you just paste it in the Front panel, it will look like it accept an array. However, if you create a cluster with t0, dt and Y, it will adapt to interpret that information.
Regards;
Enrique
www.vartortech.com
(3,998 Views)
