Where is the XNET alias file located on a cRIO?
I somehow managed to delete the XNET alias .xml file from my cRIO. The problem is the alias manager won't connect to the cRIO (error BFF63101). The connection is fine -- I can FTP to it, connect from the UI, etc. I've tried dropping the firewall but no go. I suspect it's related to the fact that the cRIO suddenly stopped allowing anonymous FTP.
Rather than spending the next several hours troubleshooting a connection problem for a 3-second file transfer, I'd rather just copy the xml file over manually. However I don't know where it goes. Can anyone point me to the right directory on the cRIO?
(4,184 Views)
Accepted by topic author Andy_Humphrey
Very long story but I finally got this working. The short version is that a couple of months back the cRIO suddenly wouldn't accept anonymous FTP so I had to put a password on the account. Annoying but not too bad. However I suspect that's why the XNET database alias manager couldn't connect. If I specified the IP then I got an error message. If I tried specifying "username:password@ipaddress" it complained that was not a valid IP address.
While fiddling around with this, suddenly I couldn't connect via the web. It said the web server was not working. So I reinstalled the web server software. I wondered if it would allow anonymous FTP now so I removed the password from the account. Previously when I tried to do that it would say I couldn't have an account with a blank password, but this time it took it. Now I could connect with the alias manager and it worked just fine. Aliases uploaded, and my code now works. Frankly I'm still not sure what I did. Voodoo debugging: try stuff until it works.
In answer to my own question, I still have no idea where the XNET database aliases are stored but I believe that information would not have helped me anyhow. When you deploy a database, I seem to remember that LV converts it to some kind of binary format.
(4,145 Views)
We can't edit posts???
I just wanted to point out that above I of course meant "username : password @ ipaddress" (without the spaces), not the tongue-sticking-out emoticon.
(4,131 Views)
You can edit posts but I think you have a time limit on the order or 10 minutes or so, not sure what the actual limit is.
(4,125 Views)
For future reference for anyone reading this post, the XNET database files are located here on my cRIO:
var\lib\ni-xnet\dbCache
(2,289 Views)
