Where to correct the Local Cache paths for Additional Installers
According to this messagepaths to the cached installers are saved in the registry (in HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Common\Installer\ProductCache).
But this seems to have changed for LabVIEW 8.6. I do not have any such registry key. How can I teach LabVIEW 8.6 that the installer is not in its former place anymore? The build is aborted with an error message without a possibility to select a different location.
(2,371 Views)
Hi shb,
have you tryed this solution ?
http://digital.ni.com/public.nsf/allkb/AFC375154EFBD6AE8625760B005FB723?OpenDocument
Alexandre
(2,349 Views)
You can also try to modify the default pass inHKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\Common\Installer
 Try with NIDIR64 (or 32 if your working on a 32 bit OS) and NISHAREDDIR64
Alexandre
(2,338 Views)
