Where to find DAQmx Assistant function icons ?
I run LV 7.1.
I installed DAQmx 8 over DAQmx 7 since I could't find the uninstall DAQmx 7.
Right ? Wrong ?
Anyway, I do see the DAQmx 8 dir in LV's vi.lib.
MAX also confirms DAQmx 8 being there.
Under the input tab I can use the DAQ Assistant flawlessly.
However, I fail to find all of the DAQ Assistant function icons ( examples of which attached ).
What did I miss ?
Peter.
(2,660 Views)
DAQmx installation seems to be OK yet.
I found the " missing " DAQ icons under the palette tab Measure.
Sorry for the bw.
Peter.
(2,632 Views)
