Where to start
I would to know how is it possible to import data from txt file into columns if i have lines like V=0.1 mL; pH=1.4019;
Thanks in advance!
Message 1 of 15
(4,343 Views)
Start with the Examples that are included with LabVIEW.
Message 2 of 15
(4,342 Views)
The function "Read From Spreadsheet File" on the File I/O pallette would be a good place to start.
Good luck!
Message 3 of 15
(4,300 Views)
Could anyone write me a sample program how to import this data into a table and perform math operations on them, please
I would appreciate it
Message 4 of 15
(4,271 Views)
Sure, how much are you willing to pay per hour? Smiley Wink
Did you even try anything yourself? Looking at the examples or looking at the file/string functions?
Message 5 of 15
(4,264 Views)
yep i tried, but the problem is, that i couldn't manage how to import data into the table, because it has numbers and string, the best i've got is just two numbers and thats all..
Message 6 of 15
(4,260 Views)
Obviously if you want to do math you're going to have to use numeric data types.
The strings seem to be always the same, do you really need them? If so you could create 2 arrays, one with descriptors (strings) and a second one with the numbers (DBL).
Have a look at the scan from string or scan from file functions. These can handle strings and numbers.
Message 7 of 15
(4,252 Views)
start with NI LabVIEW 101...Smiley Wink
then look at the "string" and "string/number conversion" pallet, ultimately it all has to be converted to a string file..
Message 8 of 15
(4,250 Views)
Thanks guys, that was very helpful!
Is it possible to multiply number by 10 to the third power?
Message 9 of 15
(4,192 Views)
Multiply by 1000?  Look in the numeric palette and you will see a quite obvious multiply node.
Message 10 of 15
(4,188 Views)
