Which HW to use
Hi all
I have to develop an application to acquire the following signal:
- n. 7 Pulse input 24VDC
- n.5 digital input 24VDC
- n.2 temperature sersor (any type)
- n.8 analog input 0-10VDC
Wich Hardware can I use?
(2,880 Views)
At what sample rate?
Wiebe.
(2,863 Views)
What bus or form factor preferred? (i.e. USB, PCI, PXI, remote I/O).
Here is a link where you can select criteria and narrow down the possibilities. You may find that multiple devices may be required.
http://www.ni.com/dataacquisition/
(2,854 Views)
Hi
it is at very low rate, about 1 HZ
thanks
(2,828 Views)
I think Fieldpoint or Compact Fieldpoint modules can do that. You don't need
a RT controller...
Why don't you ask your local NI representative? They'll be glad to assist
you.
Wiebe.
(2,823 Views)
