Which Labview function can I use to display a graph located in a sub vi, during the running of the main vi?
Summer
(2,648 Views)
Hi, there is not such VI. You have to use graph reference. You create reference of your graph in main.vi and put it as input in sub-vi. In sub-vi create property value of the graph reference and put there your data. You will see it in main.vi.
P.S. For creating reference click right button on graph and select create/reference. Also look at examples about references in LabVIEW.
(2,648 Views)
Thanks a lot for your help.
Summer
(2,648 Views)
i am facing same problem,
i understood the concept,but unable to implement
unable to creat refernce,
if possible send me links, so that i can make it.
can you send me example code.
(2,648 Views)
