Which card under 150$?
Which DAQ card do you suggest to buy (under 150$)
I use LV3.1 Student
Thank You
(3,334 Views)
If you are on a really tight budget, buy a I2C A/D convertor. I've got one
that has three analog inputs, and one analog output. It costs less then 6
dollar. You'll have to connect it to your serial port, and write your one
drivers. The ic only has 8 pins, all comunication goes through 2 wires (and
a ground).
If it is for educational projects, this will be a great exercise.
Wiebe Walstra.
AIR technical Automation
www.air.nl
"Delta_Force" wrote in message
news:3a1c0dbc.1325578@news.libero.it...
I use LV3.1 Student
Thank You
(3,334 Views)
Dataq has a WinDAQ starter kit which has four analog in and one analog outs
which connects to your com ports. The kit includes a copy of WinDAQ and you
can download LabVIEW drivers from their web page. It's $15 and is available
at
http://www.dataq.com/cgi-local/SoftCart.exe/115.htm?E+scstore
I've got one that I'm using to develop a weather station for one of my kid's
science project. It works fine. It certainly isn't fast but for the price it
can't be beat.
On Fri, 24 Nov 2000 12:20:46 +0100, "AIR Tech. Autom." wrote:
>Hi,
d write your one
>a ground).
>Regards,
>Wiebe Walstra.
SolidWorks Research Partner National Instruments Alliance Member
Christopher Dubea Phone: (504) 847-2280
Vice President of Engineering Fax: (504) 847-2282
Moving Parts L.L.C. email: cdubea@movingpart.com
P. O. Box 6117 URL: http://www.movingpart.com
Slidell, LA 70469-6117
(3,334 Views)
Oops sorry, one digital out. No analog out.
>at
>can't be beat.
>>Hi,
tor. I've got one
>>a ground).
>>Regards,
>>Wiebe Walstra.
Moving Pa
(3,334 Views)
Try DI-194 from DATAQ for $15 or DI-151RS for $99, and find the labview driver at
www.ultimaserial.com/classroom.html
(3,334 Views)
