Which file format for a complex configuration file?
I agree that JSONtext is easiest.
greetings from the Netherlands
Message 11 of 31
(3,619 Views)
Well sounds like JSON is fairly unanimous.
Any recommendations on the libraries to use? By default I would avoid the standard Labview libs are they usually are fairly basic.
A quick look on VIPM show quite a few of them, what should I consider other than the amount of downloads (Or the fact that it came from LAVA/JKI) for my choice?
Thanks.
Vincent.
Message 12 of 31
(3,577 Views)
The fact that "JSONtext" has been mentioned 4 times in the thread should give you a hint 😉.
I've not explored all functions, but I've always found everything I needed in its palette, including malleable VIs that allow very elegant implementations.
Message 13 of 31
(3,563 Views)
That's a fair point haha
I've focused on JSON and not what's after 🙂
Thanks a lot for all inputs!
Message 14 of 31
(3,548 Views)
"Use 1 Excel workbook..."
I chose this path. Not everyone is aware that Excel spread sheets can by accessed like a database.
However, my application only ever reads from the file and stores any HW specific info (COM ports, instrument address...) in an ini file.
No need for Excel to be installed on the deployment PC either.... unless of course you want to make changes to the file locally.
Former Certified LabVIEW Developer (CLD)
Message 15 of 31
(3,525 Views)
Dang, I had no idea. Do you have any examples of this? I see the link in the image, but I'll be honest that's all Greek to me.
Message 16 of 31
(3,470 Views)
I didn't know about this possibility either and tried it out.
Message 17 of 31
(3,421 Views)
I didn't know this thanks a bunch!
For other projects we've always exported everything first as a .csv, making it a nightmare for version control and formatting ....
I think I will still go for the JSON solution specifically for this configuration though as it seems more flexible and integrated on the labview side.
But I will definitely use this elsewhere!
Message 18 of 31
(3,411 Views)
That's AWESOME! I had no idea!
Qestit Systems
Certified-LabVIEW-Developer
Message 19 of 31
(3,232 Views)
JSON all the way. The JSONext library allows you to plug almost any cluster, and it will parse it into a JSON string. This is especially useful if you want to use any web based interface - Transferring data from LV to a Javascript tool becomes trivial.
Message 20 of 31
(3,210 Views)
