Which is faster, a string search or a 1-d array search?
Which is faster? Searching a string or seaching a 1-d array of lets say 16 bit words?
(3,079 Views)
I should add that I'm using LabVIEW 2010.
(3,078 Views)
I'm not sure. Maybe someone knows. For what it's worth when I want to time something I use this.
LabVIEW 2012
(3,054 Views)
They are both very fast .... In the time it took to ask the question, you probably could have benchmarked it yourself. 😄
The question is a bit vague.
  • Do you need to find the first match or all matches?
  • How big is the array or the string?
  • What are you searching for in the string, also 2 adjacent bytes? Do they need to be start with an even numbered element position?
  • Where is the data coming from? What is the original datatype?
  • Can we make additional assumptions? (e.g. if the array is sorted, we could do a binary search).
(3,045 Views)
