Which is the easiest way to read an XML tag value
Hi all,
Im not at all experienced in the use of XML parser library.
How can I extract the value of any TAG?
I use the Get All matched node (See attachment). Get XML gives me:
<title> AAAA </ title>
How can I extract directly the value of the tag (AAAA), without XML tags?
Thanks to all
(3,501 Views)
Sorry. I forgot the attachment:
(3,483 Views)
Accepted by topic author andcadev
You could use the Get Node Text Content.vi from the same palette as the other XML function you are using.
Of with a property node use the "Node value".
(3,475 Views)
(3,466 Views)
