Which module do I choose for reading voltages
Hi All,
Could someone give me some advice in there opinion on which SCXI
voltage module to choose please.
I want to log analog voltages ranging from the low mvolts to volts.
I'm looking at between the SCXI-1100, the SCXI-1102 and the
SCXI-1102B/C. Could someone also explain the filtering rate as well,
what effect this has on the signal etc.
Thanks in advance
Nat
(2,488 Views)
Hi Natalie,
I know this is not the answer you are looking for, but probably, the best solution is to call your local NI Field/Sales Engineer and explain him/her what you are trying to do. Also, it will be easier to disscuss price, performance and other parameters that must be considered when taking such a decision.(usually, his/her e-mail/phone is in the bottom-left page corner when logging to "MyNI" account)
Good Luck
(2,488 Views)
