Which module(s) does nipxirmu.dll belong to?
NI-PAL Service Manager is throwing an error each time I boot Windows (WinXP SP2).  I believe the error message points to nipxirmu.dll as the problem.  Based on previous discussion in this forum, it seems like the prescription is to remove the offending module and then re-install.  But which module does this DLL belong to?
Nick
"You keep using that word. I do not think it means what you think it means." - Inigo Montoya
(4,634 Views)
Hi Nick,
The nipxirmu.dll belongs to the DAQmx driver so you might have to reinstall NI-DAQmx. The latest version is DAQmx 8.0.1.
Sometimes is possible that the file that got corrupted is located under the Data folder in C:\Program Files\National Instruments\MAX. You can try deleting this folder before uninstalling DAQmx. Keep in mind that deleting this folder will erase any tasks or board names you had created in MAX. In order to delete the Data folder you have to stop the "nimxs.exe" from the Task Manager Processes. If this doesn't fix your problem, then you'll have uninstall/reinstall DAQmx. (Inconceivable!Smiley Wink)
Good luck,
Tica T
(4,621 Views)
