‎06-17-2011 12:23 PM
Which port should I use if my device output is a 12 pin ribbon cable? Can I adapt it and feed it to the GPIB port?
‎06-17-2011 12:29 PM
Only if it is a GPIB bus which it is not since there are only 12 wires.
‎06-17-2011 01:05 PM
What is the device?
‎06-17-2011 01:15 PM
Probably talking about this.
‎06-17-2011 01:35 PM
If the device in question is the CMOS sensor then you should be able to follow the instructions in the data sheet to collect the VOUT1 and VOUT2 signals. I'm not sure if a standard video capture card would work with that sensor.
I'd recommend calling the device manufacturer and asking them the best way to interface with the sensor.
‎06-17-2011 03:13 PM
thanks, ill try that
