Which versions of Labview are compatible with the real-Time Module?
I would like to know which versions of Labview are compatible with the Real-Time Module from NI.
Are Labview 6i and LAbview 6.1 compatible?
Also..would it be possible to use the compact Fieldpoint modules if i have the base labview package and the real'time module?
What are the minimum software requirements to create aplications for Fieldpoint? That is..what Labview Package and Real-Time module do i need in order to develop applications for Fieldpoint controllers?
thanks for your help
(2,716 Views)
eromero;
You need LabVIEW RT:
http://www.ni.com/labviewrt
LabVIEW RT is an add-on to LabVIEW. There is a FAQ about LabVIEW RT.
If you develop an application with LabVIEW 6i, you can open it in LabVIEW 6.1. The opposite is not possible, however you can save 6.1 application as 6i by selecting "Save with options" from the File menu.
I am not knowledgable about Fieldpoint. There is a FAQ about Fieldpoint. Fieldpoint includes VIs that you need to develop your application in LabVIEW.
I hope this references will answer all your questions. You can always post your questions in the LabVIEW RT Discussion Forum and the Fieldpoint Discussion Forum.
Regards;
Enrique Vargas
www.vartortech.com
(2,716 Views)
