Which .vi from the Agilent 34790 library replaces the HP34790 single point.vi?
I am trying to upgrade some old VIs which used the HP34790 library. I wanted to use the Agilent 34790 library and I found that all of the vis that i remapped to the new library matched except the Single Point.vi. What happend to this .vi was it renamed or removed? Can I use another vi that does the same function and has the same connector plane?
(2,468 Views)
Hi zblack,
Do you mean the Instrument Driver for the 34970?  I'm not sure where you got the old library, or what the code looks like for the Single Point.vi, but you can use another VI and modify it to match the single point, or build your own if you like.  For that matter, you could find the old VI and just save it as a different name and use it in your code.
If there is a driver that is not available that you would like to request, you can submit a request form online.
Hope this helps!
Adam W
Applications Engineering
(2,450 Views)
