While creating an EXE, my GUI's Front Panel is too big and needs to have scrollbars to get at items offscreen.
All,
For my needs, I have several of my Laptop PCs with the Run Time Engine installed on them and will run the VI Front Panels started as an EXE.
I am making executables with my LabVIEW Professional development systems' Project explorer.
When I start the VI (by way of EXE), I don't have right and bottom window scrollbars to get at items that are a few inches of the screen.
Can anyone help on this?
(1,418 Views)
In the build spec for the executable you can set the window properties which include whether the scroll bar should be displayed or not.
However, I would recommend that you consider a redesign of the UI to make it more user friendly. For instance, use tab controls to group similar related items and only display those. This makes for a better user experience rather than having the user scroll around.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(1,409 Views)
