While installing LabVIEW 7 Express on MS2000, I get "Fatal Error Unhandled MSI Error"
Setup program fails after the second aceptance screen.
(2,951 Views)
i had the same problem and i 'think' i neede to get the latest installer...
good luck
(2,951 Views)
Chris,
The MSI Error implies that the Microsoft Installer(MSI) Engine crashed. This is the software that handles all installation and uninstallation on your computer.
I am assuming you are using Windows 2000. If so you can download and install the MSI engine from Microsoft here.
Just download and run the installer and it will install MSI engine 2.0
(2,951 Views)
