While logging the data in CITADEL database , it misses the reading
Basically we are collecting the data from the FP1600 module & logging the CITADEL database. Sometime it misses the data & do not logg to database
(2,373 Views)
that's a hard statement. Could you be more specific on how you encounter this problem? Do you think the DSC Engine gets the correct values but it does not log all of them to the database?
You might consider to contact the National Instruments support team to figure out specifically where could be the problem.
Hope this helps
Roland
www.ni.com/ask
(2,373 Views)
