While loop Control Problem / button problem
According to my program, when user hits the toggle button the program starts to read from serial port. how it does this, button is wired to case structure and inside the case structure I defined while loop to maintain reading operation.. but the problem is when I hit the read toggle button to stop the program, it does not work since it cannot stop the while loop, still I have no solution, I will add the VI that I try some solutions on it..
"You live in a graphical world. Why not program in one?"
(2,680 Views)
(2,676 Views)
