While loop Interation counter
I was doing some system performance testing using LabVIEW and noticed that the while loop iteration counter counts up to 2147483647 and stops. I understand that that is the i32 limit, but that seems like a problem for software that needs to run forever. Depending on the speed of your loop you can run into that limit quickly, at which point the built in iteration counter is useless.
Anyone run into this? I can think of RT code that I've written in years past that likely died for this reason after a few months and started back up when I rebooted and ran fine for a few months before it did the same thing. Curious what people's thoughts are.
Message 1 of 8
(4,035 Views)
Hi AMyth,
use a shift register and create your own counter, using an U64...
This "problem" is even more prominent on FPGA, with loop rates at 40MHz or more.
Message 2 of 8
(4,022 Views)
Gerd is correct, of course. The question is why your code even depends on [i] if it should run and thus grow forever?
Message 3 of 8
(3,992 Views)
That's why you can hide the Iteration Terminal in >LV20 😁.
Sure, 21 years ago.
If you program long enough you'll run into this, make a palm face, and hopefully remember it...
I'm sure everyone programming an FPGA for the first time makes this mistake at least once.
Note the huge difference between an U64 and an I32 on an FPGA. It won't run forever, but even at 25 ns iterations, it will last long enough.
Message 4 of 8
(3,944 Views)
Well now I know better :). I just assumed that "i" would roll over when ti reached a limit. But it stops! That's what was shocking.
Message 5 of 8
(3,901 Views)
I would be even more shocked if it would roll over and output negative values starting with -2147483648! 😄
(It really depends on the use case. For example if you just want to distinguish odd vs even iterations, a rollover would be preferable, but there are probably better alternatives. 🙂 )
Message 6 of 8
(3,900 Views)
Of course it depends on what you are doing with it. I think I assumed behavior without testing and that's my fault. I now know better and will have to go check all my long running code and ensure it's not dependent on "i".
Message 7 of 8
(3,888 Views)
This one takes about 4 seconds on my rig (And 1-2 seconds longer with debugging enabled). 😄
Message 8 of 8
(3,883 Views)
