While loop problem
Hi All,
Now I have a problem I wanna solve. Inside a while loop I have two (2) flat sequence structures. It is apparent that if I have different values for X any Y, they will arrive at the destination after different times. Is there a way I can make X and Y get to the final destination at the same time say after 5 seconds if they have different values? Any suggestion or clues will be highly appreciated. Attached is my simple Vi
Kind Regards,
Opuk
(3,727 Views)
the data flow paradigm means, that your hardware-write will wait until both inputs have arrived,
so there really is no need to have the flat-sequence structures for this,
i use them to only check the STOP var at the end (which might be useful for long-execution-loops)
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,696 Views)
Opuk wrote:  It is apparent that if I have different values for X any Y, they will arrive at the destination after different times. Is there a way I can make X and Y get to the final destination at the same time say after 5 seconds if they have different values?
What exactly do you mean by "destination"?  The final value of the output?
You could do the math to see how large of steps you need in order to reach your destination in N steps.  Store that value in a shift register and keep stepping by that value until you reach your final value.
(3,666 Views)
