While loop question
Put the event structure inside the first sequence frame.  Actually, you would be able to eliminate the sequence structure entirely.
You should also make your guess a U8 to match your datatype and limit the range of entry from 1 to 5 for valid guesses.
Message 11 of 12
(732 Views)
you also do not need the sequence structure most times if you think you need a sequence structure..you dont so i would keep everything in the sequece structure but loose the sequence structure.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 12 of 12
(730 Views)
