While loop
I am just developing a code.
Its purpose is it needs to increment to a set of value(for ex: from 1 to 1000) and then it needs to reset and repeat the same until the stop button is pressed.
Also I need to find out how many times it has repeated that.
Please help me how to reset the while loop and start counting again.I have attached my code.
(3,663 Views)
I've done a simple example with what you want.
Message Edited by Jorge Amaral on 04-22-2008 05:25 AM
Software developer
www.mcm-electronics.com
PORTUGAL
(3,660 Views)
Hope this helps....
Mathan
Don't forget to rate a good answer
(3,627 Views)
i recommend you two things:
1.) Clean up your sourcecode. It is on the edge of getting unreadable. Get accustomed to document your code.
2.) Use the quotient&remainder function out of the numeric palette. It does exacly what you are looking for
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,620 Views)
This would only work if your loop was running pretty quickly, but I only have 8.2 so I can't tell whether it is or not.  If it's running fast enough, this is your best bet.
Message Edited by JeffOverton on 04-22-2008 08:11 AM
(3,615 Views)
Thanks Jorge
Really thats the one i was looking for.
Good answer
(3,587 Views)
Thanks everyone for your help
(3,586 Views)
