While trying to build a dll I revive an error
I succeed to build the dll on one computer, but when I am trying to build the same code on other computer I receive the attached error.
Please find the h file that Labview build on the first computer.
Regards
Gabi
(3,487 Views)
(3,478 Views)
Hi
I am aware to this bug and I already did the workaround. It doesn't help.
Gabi
(3,460 Views)
Hi Gabi,
Are you using LV2009, if so do you have LV2009 SP1 installed ?
Thanks!
(3,429 Views)
Hi
I am using LV2009 f3
Gabi
(3,414 Views)
Hi Gabi,
It is recommended by NI to install LV2009_SP1. It has fixed many issues. Here is the link to NI LabVIEW 2009 Service Pack 1
Esmail Hamdan | Applications Engineering | National Instruments
(3,391 Views)
I have the same issue with LV2010. What can I do?
There is no lvdb.exe in the applibd folder.
regards
MB
(3,206 Views)
