White Screen of "Busy"
I have a large program using many variables and lots of TDM data archiving. I am not using TDMS at this point and maybe I should. As an example, I take ~800 samples with two 4224 DAQs for a total of 1600 samples. This is stored in an array. When archived to disk, it gets added to other data for a large write. As a result of the mixing, each TDM write is 50 Channels wide X 800 repeats = 40000 data writes. This takes ~ 2 minutes to complete the write process.  I have previously opened up a record and then store all the data via calling a "write" subvi in a for loop. The write subvi is the one that stores 50 channels EACH time it is called. After the data is stored, I close the record. OK, TDMS would probably make this a lot faster. The write process is my last part of the test I made. After that, it just more or less does some simple housekeeping and ghen exits.
My real question is: When it is doing its housekeeping (simple closings, resetting DIOs, etc). I have this WHITE SCREEN OF "BUSY" with nothing showing on the screen. It is 100% white. Nothing is harmed, no data impacted, no changes to the program. It is just like LV is taking a break or real busy doing something.....like maybe cleaning its own house before returning to normal.
I use the same housekeeping routines during exit for at least 8 other tests and this does not happen. The main difference between the other tests and the problem child is storing the mux data in the array and the extensive writes.
(2,581 Views)
Are you building an array of data and attempting to write it all at once at the end of your application??
Is this when your program becomes 'busy'??
If yes, the best thing would be to keep appending data to the file as and when acquired and avoid using storage arrays altogether
(2,562 Views)
