Who can I implement this function?
I've implemented the derivative function:
p[n]=2y[n-2]-y[n-1]-2y[n]-y[n+1]+2y[n+2]
using the shift register in a for loop, where I enter the x[n] signal.
Now i have to make this sum using the other function inside the sum...
s[n]=SUM(from k=1 to 16)(p[n-k+1]*(16-k+1))
and I don't now how to do it!!
Can anybody help?
(2,703 Views)
Please help!!
(2,667 Views)
If you only need to sum elements of an array (index 1 to 16), use the Add Array Elements VI. You can find it in the numerical palette.
Hope this helps,
(2,592 Views)
