Who can create a clock for me with the following functions??
Hi there
Who can create a clock for me with the following functions:
-> Start
When you press the start button the clock is running
-> Stop/Reset
When you press stop/reset the clock tops and waits to be started again
with the start button. however when you press this button and you start
again the clock runs from the start time.
-> pause
When you press the pause button the clock stops running but the remaining
time stays
-> Set time (control)
-> Visual lamp for running
-> Visual for remaining time
I want to use this clock for a teststand
When i have a flow- or pressure drop the clock have to be paused, that i can
make some repairs on the system.
I'm wor
king with: Labview 6.1 and Fieldpoint
Tia Bart
(2,830 Views)
Can you be a little more specific on your timer?
From what I understand:
I believe you want a countdown timer. You can set the time from which you would like it to count down. When the start button is pressed, it starts counting down.
When you press stop, the time stops. If you press Start again, it resets to the time from which you would like it to count down, and goes again.
If you press pause, it stops counting down, but if you release pause, it continues where it left off.
Am I understanding correctly?
Mark
(2,830 Views)
Mark,
i give more details what i need on the timer.
Example:
Set time: 96 hours
Press start the timer start to run, and counting down. When
it is counting down, the led countdown is on
Press pause, the timer stops but the remaining time stays on
the counter and the led countdown is switched off
Press stop, the timer stops and reset to the start position
For the switches the mechanical action is: Switch until released.
The LED is for indication and control for opening valves and put power on
machines in the test stand
it is a pitty that we cann´t post any vi´s or llb to this group.
I can send you a sample of the vi where i´m working on.
Bart
"markwys
ong" schreef in bericht
news:506500000005000000E2710100-1079395200000@exchange.ni.com...
> goes again.
> Mark
(2,830 Views)
I found it out how to get is posted, trough NI and not trough the newsgroups
Here is a sample of the vi
William aka bartblue
Running with Labview 6.1
Fieldpoint hardware
(2,830 Views)
