Who can fix my VI to work in LV8? please help...
Don't let yourself be confused by the VI name. Everything is "binary" in one way or another. If you want it as readable ASCII (e.g. comma seperated), you simply need to format your values accordingly before writing them to the file.
See attached code excerpt. See if this help. The result opens fine in excel. 🙂
(Note that even if you call the file *.xls, it is NOT an excel file, which is a proprietary microsoft format, it is just a tab separated ASCII file. Excel is simply smart enough to read it properly if you force it to open it by using an xls extension.)
Message Edited by altenbach on 11-21-2005 08:30 AM
Message 11 of 27
(1,729 Views)
Sorry missed that one.  This should be OK.  I assume you are writing text at the beginning and then writing binary data after?
Whoops,  I see you don't want binary at all.  This should do OK then.
Message Edited by rpursley8 on 11-21-2005 11:34 AM
Randall Pursley
Message 12 of 27
(1,718 Views)
No, I have never ever had write binary data in the vi ever, It used to be "Write to file.vi" which used to write tab delimited text. I installed LV8 on a brand new computer, loaded the VI written in LV7 from my network onto the new computer, and the computer with LV8 replaced all instances of "write to file.vi" with "write to binary file.vi" That is the problem. Now i need the VI repaired so it writes a tab delimited file that any excel user can open. I hope this helps.
Message 13 of 27
(1,713 Views)
Try this one.  This should put it in columns.  Forgot a CR/LF in the last one.
Randall Pursley
Message 14 of 27
(1,711 Views)
Write to file is the same as write to binary file! 😉
Somehow it seems you also want columns for date and time, as well as appropriate column headers. The attached modification seems to do this just fine. See output  as opened in excel.
Message Edited by altenbach on 11-21-2005 08:47 AM
Message 15 of 27
(1,707 Views)
Thanks guys for all the help, I am operational again.
Message 16 of 27
(1,682 Views)
I'd love for you to post the original VI. If, you had a 1D numeric array wired to the old Write File, it should have written binary then and I don't see how it could have ever worked.
Message 17 of 27
(1,672 Views)
I dont see what your getting at? It worked.
Message 18 of 27
(1,670 Views)
I translated what you had in your LabVIEW 8 program to what it would have been in your LabVIEW 7 program. In every version of LabVIEW, that would have resulted in the 1D array being written as binary - not comma separated data.
Message 19 of 27
(1,664 Views)
Yeah but too bad you did something wrong because NO it didnt write a binary file, ive never seen a binary file in my life. let it go. Put the keyboard down.
Message 20 of 27
(1,662 Views)
